Sorry in advance for a non Cobra question, but this is the best place that I knew of to get an answer.
I've been working on my '66 Mustang while looking for a donor. It is running, but leaks (squirts) gas from around the fuel filter where it screws into the carb onto the manifold. The threads in the carb are stripped, but I can tighten the filter by hand until I cannot turn it anymore. If I put a wrench to it, the filter pops back a couple of threads and is loose again.
This is the original 2V carb and I plan to replace it with a 4V in the future. I am currently trying to move and do not wish to replace it and the manifold at this time. Nor do I wish to pull the carb. Is there anything that I can use to temporarily seal the filter to the carb? Will gasket sealer work? I will just need this to work long enough to drive the car to a new location which should be less than 10 miles.
Please excuse the long post. Thanks in advance.
Mike F.
Mike F.
