<BLOCKQUOTE>quote:</font><HR>Originally posted by Barry Mattingly:
Cobra Earl -
I have the same gearing and final drive ratios as you (3.55's and .68 OD)...how does this combo work out, for highway and/or track use?
[ March 25, 2002: Message edited by: Barry Mattingly ]<HR></BLOCKQUOTE>
My problem is....At VIR, you can open it up on the back stretch. with stock heads with a b cam, my engine runs out of steam at about 5500 or 117 mph. I shift and the rpm drops to about 3700. It sure does not have any hp at 3700 so to get to even 120 mph, i have to rev it to about 5700. I dont like to hold it at 5700.
With a 3.27 and a .8 it would go 127 at 5500. If i shifted, the rpm would fall to 4400. You have some actual hp at 4400.
Beside, 127 is fast enough for me. would not mind hitting 130 some time tho. with my transmission and 3.55 gears, id have to wring its tail to 6100 to get to 130. Id hate like he!! to blow it up AGAIN.
For road racing and using all the gears, a 3.73 or 4.10 with the .8 is probably the way to go.
Here are the top speed numbers for 25.5 inch tires with the .68 OD at 6000rpm.
..xxx. 273.. 327.. 355.. 373.. 410
..4th. 167.. 139.. 128.. 122.. 111
..5th. 245.. 205.. 189.. 179.. 163
60mph 1468 1758 1909 2005 2204RPM
With .80 OD:
..5th. 208.. 174.. 160.. 153.. 139
60mph 1727 2068 2246 2949 2584RPM
I think you can see that to be able to use the WHOLE Rpm range in all gears, a 373 or 410 with the .8 would be the only way to go with a SERIOUS road racer.
For a NON SERIOUS road racer, a 3.27 is probably more reasonable because you can get to 139 in Fourth. and stillhave the cruising RPM.
FOR the street, a 355 is a great rear even with the .68 OD. But, we can dream.
Hope this helps CONFUSE the He!! out of you.
TO MUCH INFORMATION
Earl
[ March 26, 2002: Message edited by: CobraEarl ]
