Status
Not open for further replies.
Hi guys -
Need to install an Autometer oil temp sender on my EFI 302 w/ Levy road racing pan.
Where is the best location? I guess I could pull the oil pan and drill a hole, but I'd rather not. :eek:
Anyone make an oil pressure sender tap 'extension' with two taps that might work (this is installed on the left front lower side of the block)? (I have a 4" extension that Gordon installed now, but it only has one tap for the oil pressure sender).
Pro FFR Builder and Moderator
Like Alain Said. When the filter adapter is on the engine, use the lower rear port for the temp sensor. This is as the oil comes out of the pan.
I was not planning on using the remote adapter, as I have the Tristate 4-4 headers/pipes.
I guess I might go ahead and add an oil cooler; if so, is there an in-line fitting I can add to use for the sender?
Status
