Super Moderator
Is the hole in the engine block next to the fuel pump mount the only location for a electric oil pressure sender? My sender is 1/4" NPT and the hole appears to be 3/8" NPT. And the sender is HUGE! If that is the only port, it looks like I'll have to use a reducer, extension, and 45º block. :(
Well, you could always convert over to a Ford Motorsport dry sump block, they use a 1/2" NPT fitting :D
Seriously, what you are looking for is an oil pressure extension log, either at a junk yard or the one of the Mustang parts houses such as PPI or Ford parts online. John
Bill - Go to a local bone-yard and pull the steel adapter off any 302/351w donor out there.. I would bet that you could even buy one from a vendor here like Max at 5-Star or Mike Fortes..
Shade Tree Mechanic
Super Moderator
Scalded Dog, that is the problem AND the fix. Thanks so much for showing me the way.
Cheers
