1 - 3 of 3 Posts
In order to clear the mechanical fuel pump, I used Russell 120 degree fittings coming out of the Canton oil adapter to run to the remote oil filter. I started the engine and have a small leak in one of the fittings between the pipe bend and backside of the female nut fitting. Anyone else experience this....
section 8
only when they wernt tite enough, the depend on the flare for the seal. It's ppssible it's coming from the threads too. try a SMALL amount of pipe dope on the threads and tighten it super tight. Bob
1 - 3 of 3 Posts
