They're everywhere.Do they even have a Wally World in the Netherlands?
I am afraid not because there is some movement of the oil pressue gauge when the engine is running.I'm hoping it's a loose sending unit wire!!!
Yes the oil temperature got up to 150 F. I drove about 2 miles. I will follow up on the idea of checking the gauge.But if it's almost zero and you drove it around long enough to get the oil temp up, it's probably a bad gauge. Get a cheap mechanical gauge ...
I have shorty header. That's why it is so difficult to see the arrow in and out. I am afraid I have to disassemble the cats and the shorty header in order to check center to center.Tale a look at the block adapter and the filter mount. One port goes to the center, and one port goes to the outside. Connect center to center, and outside to outside.
