1 - 3 of 3 Posts
This is a bit off-topic, as it isn't really about the FFR cars, but this happens to be probably one of the 3 most active boards that involves any sort of kitcar (most general kit boards are totally dead). Also, for this post, I wish to distinguish a full "kit car" from a "rebody". For my intent here, something like the FFR cars, whereby you have a chassis and body and assemble the car yourself is what constitutes a kitcar. Cars like the Corvette based 365GTS Daytona, Datsun based 250GTOs, and VW based 356 Speedsters would all be rebodies -- using an existing car and bolting/glassing a different body to it.
I've done a few searches in the FFCars.com archives, and from what I see about full fledged kitcars is that there is a real grey area when it comes to registration and insurance. It seems that many are indeed able to get the cars registered as a vintage year, and thus skip compliance with modern, stringent safety and emissions regulations. This also seems to be both hazy in its legality, and not a sure thing. It seems that the titles do not always transfer, particularily if someone moves from a lenient state to a strict state. For example, registering a Cobra built in 2000 in Florida as a 1965 Roadster, and upon moving to New York having your title revoked and being forced to register it as a 2000 car.
Now, my real question would be, do rebodies just keep their title? Let's say you build one of the Ferraari 365GTS Daytona's on a 1970 Corvette, and really do it perfect - I mean you cannot tell the car was a Corvette without getting underneath it. Not even the drivetrain is stock (for our fantasy, lets say you gutted a ZR1 - ok?).
From the way I've read things, you're in the clear because in all states that require rigid, annual testing - cars '72 and older are exempt, and this would hold up no matter if you moved from NY to VA to CA. If the VIN is clear, so are you.
So, my two questions are - (1) Are my facts relatively straight? (2) Is there any circumstance where a state would require a manufactured vehicle to be re-registered as a custom or assembled vehicle?
Andrew
· Planning & Saving
Andrew,
You would have to have the VIN on the frame. It's illegal to remove it, from what I know. The VIN would be a dead give away to what the car is really. Unless you can get a new VIN on the vehicle, but I'm thinking this may be illegal too.
Trav :(
Well, essentially I'm trying to factor in the registration issue as to which chassis I utilize. I'm building a custom body, and had been courting FFR for a chassis from the Daytona (basically a kit without the body), among other replica makers.
I've also entertained the possibility of building the body on a mid year Corvette; probably '68 - '72, which would keep me emissions exempt while also not getting into the high prices of the classic 2nd Generation "Stingray" (the C2 and C3 share the same chassis). Now, obviously there are definite advantages to the Cobra/Daytona chassis over the Corvette, but this could be a determining factor for me.
I live in Florida now, and they don't require annual checks here, but in a year or two I will likely be moving back up to the Northeast for job reasons. What really alarmed me is when I read about states revoking vintage-dated titles on kits and force a current year, specialty title; which seems to happen often enough when someone makes a move from a "lenient" to "strict" enforcement state.
Andrew
1 - 3 of 3 Posts
