I've been following the very useful Not Starting thread because I'm having a similar problem. No fuel pump and no starter. '92 donor. I'll do all the tracing using the other thread but hope someone might have some suggestions for my no crank condition.
The solenoid is fine. If I jumper 12V to the little post, the engine cranks.
I put a meter on the R/G wire that goes to the post and found that when I turn the key to start, and press the clutch pedal, it goes from floating to zero volts.
Any thoughts?
Any thoughts?
