what are the options if you're not using the a heater for looping the two black tubes that run along the pass. side valve cover to the rear of the motor,they are two differnt size hose, any suggestions??? thanks
Best idea: lose'm. Cap the water pump return, and remove the temp sensor from the pipe and put it directly into the intake manifold hole where the pipe was previously mounted. This assumes that you are blocking the EGR circuit and wont need to run coolant to cool the throttle body spacer.
Plan B, get your parts guy to let you browse his wall of hoses, odds are something will be useable for the two diameters.
Are you sure that you don't want a heater? Phoenix must get cool in the winter--San Diego does.
lets just say I wouldn't be driving it tonight!!! It's sorta cold out...Plan B is what I was thinking sounds good, won't be using the air pump or any of the stuff either..thanks
First question, have you ever owned a convertible? I am guessing you haven't. That being the case, you will find that you use the heater very often. If the temperature gets below 70, but you want the cruise with the top down, you can, so long as you have a heater. Get one.
My understanding is that Napa Auto parts sell them. I had seen a previous post that even gave the part number, I am unable to find it. My donor had the bypass hose on it. Good luck
