1 - 3 of 3 Posts
After reading a few posts, I was thinking about getting a new tank. As I am going with a carb, should I get an 85 tank? Will it fit? Can I use the sender from the 89? Where do I get the pickup? Or should I get the 89 tank and replace the pump with some tubing? Any help is apreciated.
Sarcasm King
I have a 351C, with a fuel cell, same openings as OEM tank for 87-93. Not sure of other years. I think 85 and 86 are same b/c I use an 85 fuel pump and it fits perfect. As per suggested by FFR Joe in tech support. 85's had carb. This pump has a return line too. With a good regulator (mallory for me), it works great!.
I used an '87 tank and a mechanical pump - I bent and brazed a pipe into the place where the intank pump was - if I had to do it again I would just get the pick up from Mark at Breeze.
The '85 tank will fit and work but I don't know about the sender.
Scott
1 - 3 of 3 Posts
