Ok, whos going to be the first to shoe horn one of these into a roadster?
shttps://www.yahoo.com/autos/ford-now-sell-7-3-130600637.html
Curious George
  1. the Godzilla engine is about 2.5 inches wider than the 351 Windsor.
  2. On the engine length measurement, the 7.3-liter V8 was about 1.25-inches longer. Those figures aren’t vastly different between the two.
  3. Compared to the Coyote V8, the Godzilla engine is narrower than the Coyote
  4. Weight: (it's an anchor!)
    1. the 7.3L weighs 538 pounds !!
    2. The Windsor weighed in at 471 lbs.
    3. Coyote engine at just 404 lbs.
  5. The result was a naturally aspirated engine that makes nearly 600 horsepower and over 550 pound-feet of torque.
140lbs more than a coyote, thats a problem. At least they were able to get it revved out to 6500 on the stock rods and pistons. Personally I dont think the fun starts until 7k but there are plenty of builds on here that are well under 6500 rpm motors.
Not sure why this gets suggested for a cobra? It's designed for a work vehicle. Has high torque at lower rpm's, it heavy and not a high rpm, high HP engine. Put it in a work truck and tow 10,000# all day long, a replacement for diesel engines.
Want a big high torque, high HP engine, then this is the one to buy.
It ain't a gonna' work boys. This engine is too deep below the crankshaft...it has an extended skirt that runs beyond the crankshaft and includes a variable displacement oil pump which houses all of the regulating controls inside the oil pan. Take a look at how far below the crankshaft centerline the bottom of that pan is...and see all that stuff hanging off of the pan
359417
No way it's going to be able to work in a roadster with 4" of ground clearance unless someone comes up with a dry sump and remote belt driven oil pump. Rich is spot on; it's a heavy, low revving, high torque stump puller truck engine. It'd be great in an old F series pickup but not in our cars.
