· Senior Charter Member
Where do I get a throttle cable for my ffr with a 351 windsor with a carb...thanks...later...
· Mid Ohio Loopster
I was able to use the one off my '89 mustang(4 cyl). had to make a bracket to hold it at the front of the block, and bought a kit with different size ball pivot pieces from the auto parts store(made by holley). put the correct size ball on the carb, made the bracket to fit so the carb would open all the way. so far seems to work fine.
scott
· Senior Member
I found the 36" Lokar a little bit tight,had to make a fairly sharp corner to make it fit, I traded up to a Custom Lokar 40" from Fortes
· Premium Member
Hi 79Pacecar,
I had Lokar make 50 custom cables that are 42" long. They can be cut to fit, but I found the 36" cable not quite long enough.
Mike Forte
Forte's Parts Connection
376 R Cambridge Street
Burlington, MA 01803
781-273-9900
