1 - 10 of 10 Posts
Any recomendation on an ignition system for a 302 crate motor with roller cam? Need Steel gear?
Dennis
YES, Steel gear!
If you go carb, use either one from a 85 GT (Mike Forte should be able to get you one that has the steel gear for sure) or MSD-8598, also steel.
Not sure for the EFI numbers but you can find them in the SUmmit catalog.
Lukas
Try one of these: Performance Distributors It has worked great in my 302. When you order one, you fill out a fairly extensive order form. Max RPM's, weight (car not driver!), etc. It was less expensive than the complete dist., wires, coil, looms etc. from JEGS or Summit.
Ray
Former Roadster Owner
Crane has some very nice ignition equipment out. I have their new street/race distributor. I've seen nothing like it. It's awesome. It won a SEMA award about a year ago. Total and vacuum advance settings can be set with the turn of a dial. You must use a box with a magnetic trigger singal. The cost is less than the Performance Distributor which I was considering. Make sure you check them out.--Dan
dennis, i had no idea you could get these from
autozone!
are you positive this has a steel gear?
steel- has a machined look to all of it.
iron- just the gear part is machined..
if so, great starting point!
Dennis, I went MSD, but let a Machinist talk me into a bronze gear. BAD MISTAKE. I caught it at 6000 miles just before EXPENSIVE things were going to happen.
By all means get the Steel, but don't rely on Autozone. A search perhaps all the way back to 2002 you will find a Cobra Earl posting on how to check to make sure your gear is Steel. DON'T GUESS. Check it.
Owenmustang,
You can indeed get them from Autozone. Unfortunately, for some reason not all of them have a steel gear although they are supposed to. So make sure you check REAL carefull what they give you!
Lukas
Well, I took a picture of it but can't load it onto the site. Dark gray has a little machined ridge around the bottom. I can send a pic to someone if they think they can tell which it is. :cool:
1 - 10 of 10 Posts
