1 - 11 of 11 Posts
Hi guys...I need a new part...
I have had a thermostat housing (like in the picture) on my 351 Winsdor for the last 8,000 miles without problems but today it started to leak...pretty bad actually.
I haven't taken it apart yet because I was letting things cool but I think I will replace the housing.
Does anyone know of a good alternative to fit my application?
Marc
Cobra Earl sells a nice billitt piece!
A billit piece for $100. Or another Mr. Gasket piece for $24.
The questionis, where does it leak? A common spot is the threads of the bypass nipple. I coated mine with JB weld, and screwed it in as tight as I could get it with a pair of vice grips. Been leak free for about 20K miles or so.
Auto Zone or Advance Auto. Tell them you have a 87 Mustang 5.0 and it will run you about $12 but it wont be all pretty shiney but it will last several hundred thousand miles.
Tool Collector
X2. Paint it if you want to pretty it up. Frank
Discussion Starter #8
I hope to take mine apart this evening. I'll confirm that it is leaking from the gasket area first.
I would prefer something with the same configuration as the stock instead of going with a 2 piece like Roadster Earl's.
Whatever I use, I hope I don't have to go back to it again anytime soon. This was a real PITA when I first got the car running and I thought I had it solved. At this point, I don't care what it looks like.
Marc
Can't you just replace the gasket?
Mid Ohio Loopster
If it's chromed, sand off the chrome on the mating surfaces or it will never stop leaking.
X2. I have the same piece and did this sanding as well. I only have a few hours on the engine, but experience no leaks from that housing.
1 - 11 of 11 Posts
