I have a T-Bird Turbo Coupe rear with the calipers relocated to the 2 O'clock position (vs. 10 O'clock stock position). I guess this means that the parking brake cable needs to be a bit longer since it has to loop around the coil overs now. I have noticed that some guys felt that the Mustang cables were a too long so maybe this would work out OK. Which parking brake cables do I need? I am using a Fox handle if that matters. Thanks for your advice!
section 8
uhhh good question where is commander oben?? I used a homemade bracket moved 4" rearward and cutoff the FFR one. Are the cables too long or just the cable housings?? Bob
Master Blaster
94 gt cables should work (same setup with 1990 stock handle on mine and it works good, napa cables totaling $40)
The FX length cables should work fine. The distance is actually shorter with the calipers mounted to the front. A C instead of an S. HTH, Cheers Richard.
