1 - 3 of 3 Posts
Whitby cube heater
There is some conflicting info when I did a search about routing the hoses. The outlet to the heater (HOT) goes from top of the manifold near the thermostat housing to the highest inlet on the cube heater. ( Also the hose where the cutoff should be installed if desired). Then return from the heater (lower outlet on the cube) back to the water pump.
Is that the correct routing?
Manos
That sounds right. It's how mine is plumbed. In my instructions (mine's a heat/AC for my coupe from Richard Oben / North Racecars) it states either hose can go to either outlet on the evaporator as it's a closed loop, it would work either way.
HTH,
Rob
I don't mean to hijack ... any photos of how you're installing the upper hose to the manifold, including placement of the temperature sender? (Carbed Ford Racing 302) I've seen posts suggesting to connect the hose and the sender through the same threaded fitting. Is that the best option? Part numbers?
1 - 3 of 3 Posts
