1 - 2 of 2 Posts
I'm using the painless harness, 920 wire is the coil B+ that is suppose to go the positive coil post. My question is do I splice the red wire from the rev limiter to the pink coil wire and run it to the coil?
You can tie the red wire from the rev limiter into any switched 12 volt positive supply.
When they say "ignition switch or coil +" what they mean is anywhere you can get +12 volts when the key is on.
1 - 2 of 2 Posts
