1 - 3 of 3 Posts
A friend helped me remove the driver's side head, but forgot to index the head bolts. I am in the process of replacing the head gasket and find one of the bolts is double sided. Can someone check to see which hole the double sided bolt is placed? It's always the simple things that hang you up.
Mike R.
Hi Mike,
On my '87 engine it is the front bolt on the passenger side. You might want to double check that the bolts for your application are reuseable though. Some are not. Someone else here might be able to chime in on this if you give more details about the year of your engine.
Cheers, Rod
1 - 3 of 3 Posts
