I'm sure this question has been answered a number of times, but unfortunately at the time it was asked, I was not paying attention.
The fuel gauge is not registering. My tank and sending unit (new) are from a '95 mustang and the gauge is an Auto Meter purchased from F.F.
The problem is, the gauge is not working. I half filled the tank with gas and the gauge didn't move. I removed the sending unit from the tank and manually moved the float arm, but the gauge still didn't budge.
Am I supposed to install a resistor inline. Or is there something I over looked. Would appreciate any help.
Thanks...... Marty
Mine did the same thing. I have 94 sender. My issue was my AAW wiring harness needed a ground for the guages! It fixed several problems.
Rich
Marty, I have a sending unit and tank from a 94, FFR wiring harness and autometer gauges (not from FFR). I had the same issue, and I called Autometer tech. I had to send my fuel guage back to them to get the guage calibrated to that sending unit. It was quick and was about $20 I think. You might want to call autometer. good luck!
check your wiring first and make sure getting power to the gauge and that the grounds are good. also, check your sender with a voltmeter set to Ohms, and make sure you're getting the right resistance range out of it for the fuel gauge you've got. should be - 16 ohms empty, 158 ohms full
here's the diagram i made up for myself as reference. I have the Autometer Vintage gauges.
You can also put a ohm meter on the terminal coming from the sending unit and move the arm. I believe the unit you're working with should be 16-158 ohms. If it's not working, they are usually easily fixed. I have a tutorial on my website if you're interested. (It's also here somewhere)
R :D
Thanks for the advice guys. After viewing the diagram Pete sent, I realized I had switched a couple of wires on the gauge. Changed the wires around and it registers perfect now.
Again, Thanks
Marty
