1 - 3 of 3 Posts
Can anyone tell me what type of connector I need to buy to hook the neutral switch up to the stock manual T5 switch...
thanks, ed
Over Engineerer
If I recall correctly, that switch has 2 male pins. Maybe you could use 2 female bullet connectors. You'll probably need to close them up a bit with some pliers for a tight fit on the pins.
I didn't connect mine, so I should have the connector in my discarded wire box at home. I'm headed out of town tonight, but if you don't have any luck finding a solution before next Friday, PM me and I'll send it to you.
The 2 pin switch on my t-5 was for the backup light. Instead of the neutral switch, I just used the one on the clutch pedal for safety.
1 - 3 of 3 Posts
