Hi guys and gals.
Ever since I installed my McLeod scatter shield and new tranny, I've had a mysterious oil leak. While I was in doing the tranny, I also replaced the rear main seal and the pilot bearing.
After the upgrade I started seeing oil on the bottom of the bell housing and the floor. I thought I might have goofed up the rear main, so I had another one put in. It still leaks. I am now seeing oil on the outside of the scatter shield even on the top. Seems like the oil is coming from elsewhere. I looked at the base of the intake and the valve covers (best I can with the engine in the car), but don't see any leaks there.
Are there any bolts that hold on the scatter shield which go into an oil resevoir? Perhaps I missed one.
Any suggestions?
It is a 302.
Thank you
-Sean
Any suggestions?
It is a 302.
Thank you
-Sean
