to do before I go cart :D
1 Tighten coil-over shocks
2 Zip-tie hats to coil overs
3 Grease all joints
4 Install new oil adapter
5 Install Coil
6 Install new headers
7 Extend wiring and connect O2 sensors
8 Install missing water pump bolt
9 Install water pump hose clamps
10 Install Napa heater hose
11 Install vacuum lines
12 Install vacuum line plugs
13 Install speedo
14 Wire dash
15 Wire speedo to vss
16 Rewire neutral safety to clutch safety
17 Bleed brakes
18 Run backup light wire
19 Run license plate wire
20 Put in friction modifier in the rear-end
21 Rivet driver rear splash panel
22 Rivet rear firewall
23 Grease rear control arms
24 Adjust passenger side rear drum brake
25 Finish wiring brake, driving lights
26 Finish wiring fuel pump
27 Finish wiring fuel sender
28 Install and wire computer
29 Install Barometric Pressure Sensor
30 Install wiring loom
31 Attach wiring loom with rubber isolated grommets
32 Install Pro5.0 shifter boot
33 Install Drive shaft
34 Fill Transmission with ATF fluid
35 Replace blown fuses
36 Finish filling and burping cooling system
37 Bolt on steering wheel
38 Adjust Parking Brake
What do ya think?
USAF Lifer (Retired)
Depends on the date you're shooting for. Before Christmas, gonna be tough.
The end of January would be nice. Can you think of anything else I should think about?
I've got the driver seat all buttoned up, but the seat belts need to be added to the list. Good thinking, Naga.
Come on Feddersen, I think my kit came a week after yours and I go carted a month ago. Looks like about three days work to me. I think a ride for Christmas would make it a truly wonderful new year. Keep up the great work!
Yeah, I know Nels. I've been slacking, what can I say? Hey, you're on your second build, though. I'd say that's an unfair advantage. I have to figure out what I'm doing as I go, not to mention that I'm a complete mechanical idiot. My "civil servant" paycheck is my biggest crutch.
Now that I have Nels and Randy J. riding my asp, I guess I'd better get crackin' on this list.
Last thing before you start. Check the oil to be sure you put it in. Have someone handy with a fire extinguisher. Check oil pressure immediately upon startup.
