· Sarcasm King
Check this all those who are interested in a different location for an ebrake with very minor modification.
I am using Lokar's ebrake handle and cables. The intent was to put the handle in a place accesable from the drivers seat while strapped in AND wasn't in the way AND was in an "ergonomically" pleasing place. So after much planning, I decided to place it on the passenger side top of the tranny tunnel. I wanted to have the mounts under the aluminum with only the top part of the handle coming through, this would make it more low profile and I would only have to have a thin cut in the aluminum. To do this I had to mount it at an inclined angle(with respect to the mounting holes). So, I had to modify the lever arm on the bottom of the handle because the FF 3/4" frame angles upward toward the trunk bottom and the rear axle and driveshaft are there too. I simply cut a 1/4" thick piece of steel about 2.25" long, tapered it for extra clearance, and welded it on to the Lokar handle at the appropriate angle found through testing and planning. I drilled a hole and welded a nut to the 3/4" frame for the back mount. Tomorrow (hopefully), I am going to build up the front mount with 3/4" steel to match the frame. It will come up from the bottom and also over from the back to make a triangle plenty sturdy.
In the pictures, the handle appears to be angled pretty high in the "released" position (all the way down), but once the carpet and insulation is in, there will be only enough room for my knuckles (+ or - 0.25 inches).
If you notice, I had to remove the FF ebrake bracket used for the stock mustang cables, I tried to use it, but it didn't make the "cut" :D
I painted the new lever piece with rubber undercoating, my welds aren't that bad. :D
http://bellsouthpwp.net/b/e/beavis3/ebrake.htm
If you have any questions let me know.
· Sarcasm King
Discussion Starter · #2 ·
The clearance to the driveshaft is about 1.5 to 2 inches fully released. Probably about 0.75" or so when engaged, but who drives with the ebrake engaged? :confused:
· FFCobra Fanatic
I am thinking of doing the same as you did. I dont like the location of the parking brake and its either move it to where you did, or possibly a foot operated one from Lokar. Im still in the "thinkin about it" stage, and would like to see any pics from anyone who has completed this location change. I went to Sears Point a few weeks ago, saw a lot of FFR's,but not one who moved the brake. Please post any progress or problems.
· FFCobra Fanatic
Here's my ebrake install on a MKII chassis. The MKII mod is very easy since there is material there to weld to. I made a plate out of some 3/16" steel and cut ou the notch for the Lokar handle. I even used the Lokar mounting tabs.
Ben
· Sarcasm King
Damn, That would have been easier on the MKII. Mine is in the exact same location. Check my webpage tomorrow (12/13/02) for the latest pics, I have just completed all the brackets.
