Mk4 FR347 TKO600 Moser 3:31 350RWHP 350RWHP NT01s GasN Pipes Corbeau seats Celina Custom Auto paint
Well, I certainly wasn't looking forward to this job, and it didn't fail to fulfill my expectations. I didn't have a helper (or at least one who was willing to help lift this chunk of metal), so I took advantage of a winch installed on my lift. [first image] The lifting solution actually worked pretty well, and I can assure you that there's no "f...ing" way that two guys on their backs could have done this. The space (front to back) was very tight, even when the 3rd member was leveled. I made an attempt to open the gap with a big ratchet strap, but that was only little bit successful. Eventually the rear bolts lined up pretty well, and I inserted them not-quite-tight.
BUT, the front chassis bushing alignment was another story. [second image] The left-to-right spacing of the sleeves in the chassis bushings is about 1/8" narrower (1/16" on each side) than the lug spacing on the 3rd member casting. I'm having a really hard time understanding how to open up the chassis weldment to make this fit, and I doubt that the bushings have enough compliance to accept the 5/8" mounting bolts. I'm afraid that whatever I need to do will require removal of the 3rd member and some sort of butchering of the chassis.
Any advice would be appreciated.
