1 - 2 of 2 Posts
For those of you who have a Ron Davis radiator, how did you mount it? I have the lower support bar from Gordon Levy and I was looking at the set up today and I'm not clear how the lower mount should be installed and how the radiator mounts to it. If anyone has any pics that would really help me.
Trevor
On mine, the upper flange is attached to crossmember with SS bolts just as on the stock radiator. The lower support is bolted across the frame with the welded-on square tube supports against the back of the radiator to relieve the load on the upper flange. I put adhesive backed rubber on the face of the supports to keep them from scraping the radiator.
Private email me your email address and I'll send you a few pictures tonight.
1 - 2 of 2 Posts
