Picked up a set from Harbor Freight for $10. They sound great! Very loud.
I made new radiator support brackets that incorporated a mount for the horns.
I used those as well. Can't beat the price.
Lifetime Journeyman
I have them, too. Two years and they still look good, and sound like an American car horn should!
FYI, double-check if you are considering mounting your horns where I did. At this point I am strongly considering re-locating them, they are almost in direct line with the brake duct openings. I had to force the bumper bolts past them.
I mounted mine inside the nose, near the top of the radiator. Can't even see them, but the sound gets out perfectly!
Could also be an issue with fitting the rad side aluminum pieces.. Have you tried fitting them yet? You may still need to move them after all.:(
I mounted my horns to the frame X member in front of the engine. Still plenty loud at that point.
