Status
Not open for further replies.
1 - 3 of 3 Posts
· Senior Charter Member
ANYBODY USE THE FORD MOTORSPORT ADJUSTABLE CLUTCH
CABLE? WHEN YOU MOUNT THE ALUMINUM QUADRANT ON THE CLUTCH PEDAL SHAFT IS THERE ANY SPACERS OR DOES IT JUST SLIDE BACK AND FORTH ON THE SHAFT. THANKS FOR THE HELP.
ROGER
· Scalded Cat
If you go to Mike Fortes web page it shows the quadrant with a white nylon spacer. Mine also came with a spacer.
Todd
· FFCobra Craftsman
I have both the Motorsports cable and Steeda adjuster (sorry Mike did that prior to knowing you)
The cable end goes through the adjuster and over the arced aluminum alignment thingie and then on the clutch pedal end. Once you attached the other end (with the threaded rod and two nuts) to the clutch arm and adjust everything tight the play will go away....
hope that is clear to you cause I did it and it sounds as clear as mud to me.. ;)
1 - 3 of 3 Posts
Status
