1 - 2 of 2 Posts
after my 2hr drive to cms yesterday, as soon as i got inside the track, my motor quit idleing. bam nothing.. stock motor with everything stripped off. there was some talk about me having the vac. plug on the egr plugged off, something about the pintle inside not working properly.. does that thing need vac. any suggestins
Al, egr vacuum shouldn't cause idle problems. Check the TPS or the idle bypass solenoid (side of throttle body). Also check for obvious vacuum leakes like the PCV valve.
Dave
1 - 2 of 2 Posts
