1 - 3 of 3 Posts
Guys,
Just picked up a set of Prothane motor mounts. There is a marked difference between the two in the location of the stud that attaches to the frame. They are offset from the center of the mount quite a bit. So, does the bulk of the mount go forward or back in relation to the car? Unfortunately, the mounts are not marked.
Thanks in advance,
Rick
One has the stud/bolt oriented hrizontally, one vertically. You really can't mix them up.
The left one goes on the opposite side to the right one and vice Versa!!
Sorry couldn't resist.
As Joe Leone says it will be obvious when you look at the chassis.
1 - 3 of 3 Posts
