1 - 1 of 1 Posts
Considering parting with my kit. I haven’t had time to work on it between house projects and starting a business and I don’t see my self finishing in the near future. Below is a mods list I can think of off the top of my head. It does run and go kart but there are some things that need finished
things it will need: new front windshield
Ac charged
Some wiring
Vents/grills installed
Fog lights
Finish exhaust from turbo out the back
Finish interior
GTM parts list
engine:
4.8 LR4
B3R Boost ready package(stock bottom end)
Ring gaps opened
arp rod bolt, head studs, ls9 headgasket, ls2 timing chain,
trunion upgrade
BTR stage 2 twin turbo cam, pushrods, and valve springs, gm performance lifters
LS1 intake manifold, dbc throttle body
Holley oil pan tapped for return lines
New alternator, ac compressor, c5 corvette water pump and idlers
Performance ls high torque starter
fuel system:
Lingenfelter performance 255 in tank pump and genuien walbro 255 external on the other tank, -8feed, -6 return,
Holley billet fuel rails
Holley 120lb injectors
Snow performance methanol kit, with 2000cc nozzles, devils own solenoid for pwm
controlled by ecu/ low methanol level sensor tied to ecu
electronics:
Holley HP ecu with ls harness
Holley 7" touch screen digital dash
Holley gps speedometer input
Trans:
Porsche G96 transmission
Custom adpater and flyweel
Spec stage 3 clutch
new slave cylinder
factory five axles
genuine german 930cv joints race prepped
Turbos/Exhaust:
Billy Boat SS c5 headers that have been vbanded
VSracing 61mm turbos
44mm wastegates and 50mm bovs
ict billet pressure line
-10 return
Turbowerx exapump scavenge pump
Wheels/suspension
c5 corvette knuckles
ffr koni coilovers
c5 brakes from a mallet hammer
stainless lines
Vossen cv3r wheels
needs new tires
id like to get low 40s. Price is negotiable will consider trades for other sports cars with cash on either end
356765
356860
356861
1 - 1 of 1 Posts
