1 - 3 of 3 Posts
I have a Momo wheel that I would like to use. I think it has a different bolt pattern than the FFR supplied wheel. Does anyone make an adaptor that will allow usiong the Momo on the FFR hub? TIA.
Depends on other factors: Are you using Russ Thompson's turn signal. If you are, send the wheel to Russ with your FFR hub and he'll take care of it for you. It'll cost more than normal, but the results are worth it. If you are not using Russ signal and are using the FFR hub "as-is", then you can have the hub redrilled. The Momo hole pattern is only slightly larger than the FFR, but it's 30 degrees out of phase with the FFR pattern so redrilling is no problem. Lots of the Momo wheels (like mine) have exposed mounting screws so make sure you tap the new holes for a thread that'll let you get the fasteners you want.
1 - 3 of 3 Posts
