1 - 11 of 11 Posts
I have heard different things. The manual shows a picture of installation of the body with the splash guards on but tells you to install them after the body. What do you guys recommend. Should I do it now, or after the body is on.
Also, same question for that piece of aluminum that goes above the bottom of the door. Should that go on now or after?
After the body goes on. Don't trim the exhaust cut-out until the front splash panels are in, either. The splash panels will really change the fit of the pipes to the body. Temp hold in place with clecos until bodywork is done, as you will want to take the panels back out to remove and reinstall the body.
Alum panel inside the pass compartment on the X below the door can go in anytime. Its the piece that mounts horizontally on top of it that should go in after the body.
Arshia,
Hold on to both of those ites (all splash guards and the door bottoms) until the painted body is installed.
-K
yes both after the body
but i painted the rear of the rear splashguards black, they are visible from behind the car.
what origin is the name Arshia?
Pretty much what gbranham said. Fit/Cleco in while body is on in gelcoat. Remove panels, remove body, paint body, remount body, rivet panels in. HTH
Discussion Starter #7
Thanks guys for the input. Is it really going to be that visable from behind the car that I should think about painting them?
Eddie, it is Persian
Thanks again
maybe my perception is skewed a bit, my driveway is slightly angled so i see the bottom rear of the splashguards every day when i pull my daily driver into the garage next to the cobra.
some guys undercoat both sides of the splashguards when they are done, it cuts down on the noise of rocks hitting the splashguards
good luck & have fun
some have said to not use a sheet metal screw, if it makes it way out, it may find it's way into your tire.
so far, i still have sheet metal screws and have not taken that advice.
i have removed the splashguards so many times, i may have to go to a bigger screw next time, or actually use a pop rivet
1 - 11 of 11 Posts
