...When I got to the decklid I was faced with that well known and frequently discussed Mk4 license plate issue! Some guys simply trim the plate to fit but Steve has reservations about that (I suspect he thinks he might be breaking enough laws and doesn't want to give the Bloomington Police yet another excuse to write him up!). With no modifications the plate hangs over the trunk handle like a Backdraft:
I got looking at the light assembly, did some measuring and decided that if I could tuck an uncut plate up under the license lamp hood it would clear. The light bulb holder has a stud to hold the hood and lense that is not centered:
By drilling out the rivets that attach it I could flip it over and move it up 3/8". This put the stud back into the same position in relation to the hood. I drilled the rivets out of the insulator card and moved it upwards 3/8" also:
Next I cut a slot in the back of the lense which will allow the plate to slip up inside the lamp housing and reassembled the unit:
Finally I cut a length of aluminum stock and attached it to the existing mount then drilled holes which will hold the license plate about 1 1/8" higher:
All done! An uncut standard size (12" by 6") license plate now tucks up behind the lamp housing and clears the handle:
