This car was finished in 2020 and is titled in Canada.
FFR serial number: F5R1009439RD
All new parts were used except for the Engine block which was completely gone through and rebuilt. This vehicle weighs in at 1120 Kg (2420 lbs) This car is quick 0-100K 5.1 sec but that was with not too good of traction on launch.
ENGINE:
357W – Windsor small block
600 Slayer carb (electric choke) on Edlebrock aluminum intake
Flo-Tek Heads
Running right at 9.3:1 compression
Comp-Cam
Eagle Crank
350 HP with 350 Ft/lbs torque (approx)
Billet HEI distributor
Aluminum Radiator
TRANSMISSION:
Termec 5 speed
REAR END:
8.8" Ford 3-Link Complete Rear Axle Assembly w/3.55:1 gears
SUSPENSION:
Front-
FFR fully adjustable upper control arms
Lower Tubular control arms
KONI brand Coil overs shocks
Rear-
FFR 3-Link suspension with including adjustable panhard bar
FFR tubular rear lower control arms
WHEELS AND TIRES:
FFR Halibrand style 5-lug 17” wheels
Rear – 275/40ZR17 Sumitomo HTRZ
Front – 245/45ZR17 Sumitomo HTRZ
BRAKES:
Front: 11” Mustang GT
Rear: 11.65” disc
INTERIOR:
Standard FFR authentic style leather seats, door latches
5-point Simpson brand harnesses. 3” wide driver and passenger, frame mounted.
Glovebox
Willwood pedal box
Black cockpit carpet set
Interior door panels
Emergency brake boot
14” wood and aluminum steering wheel plus a padded wheel as well
Chrome passenger and Driver 3 point Roll bars
Gauges (Vintage FFR GPS metric gauges)
• Speedometer (reverse read) GPS driven (Set for 0-100 km, ¼ mile)
• Tachometer
• Oil Pressure Gauge
• Water Temperature Gauge
• Fuel Level Gauge
• Voltmeter
• Clock
OPTIONS/UPGRADES
Drivers foot box mod (for more legroom)
Dual Roll Bars Chrome
Stainless steel Front and Rear Hoop Bumpers
LOKAR E-Brake
4 into 1 Stainless Steel Side exhaust
Full length chrome side headers
Stainless steel side louvers
LED courtesy lights in cockpit, under hood and trunk
Alarm
EXTRAS SEPARATE IN BOXES
Extra chrome side mirror
Quick jacks for front and rear
EasyGuard EC003-1 Smart Key PKE Alarm System – keyless start (not installed – in box)
All paints and primers
All associated builders’ manuals and FFR component instruction sheets
Numerous parts and pieces not required for my use and too numerous to list
NEEDS TO BE DONE
Not too much. If I was to keep it I would change out the electric choke for a manual.
Paint could use a touch-up in some small places
Stereo needs replacing/upgrading
Maybe redo carpet as I cannot lay carpet for love or money
Price: $45,000 Cnd
Vehicle registration plate Car Vehicle Plant Grille
Tire Wheel Car Vehicle Plant
Vehicle Hood Car Motor vehicle Automotive lighting
Automotive tire Hood Motor vehicle Automotive exterior Steering part
Gauge Measuring instrument Gas Auto part Speedometer
Motor vehicle Car Light Automotive design Odometer
Tire Vehicle Car Wheel Motor vehicle
Vehicle Car Motor vehicle Hood Automotive exterior
Car Vehicle Hood Plant Automotive lighting
  • Like
Reactions: JKMike and 2FAST4U
