What do i need off the steering column from the donor beside the ignition switch and the turn signal stalk-i am really not sure why i need the turn signal stalk itself. Is there any part of the column i need?? I decided to go with a flaming river 18:1 manual rack and rag joint replacement connector(whatever that is called).
I did not use ANY steering parts from the donor on my MKIII. Just make sure you tell FFR which steering rack you're using, as that affects a few of the pieces they send you.
Cheers, John
Supporting Vendor & Admin
They would send the complete column from the steering wheelt up to the rack. Tell them what year your donr is so you get the right front U-joint.
