1 - 10 of 10 Posts
Hello,
since First start up i always had issue with my mechanical temp gauge as it don’t move. Bleed system still nothing, I boiled water and put barb in it and finally it moved a lil bit. Not crazy that gauge is Celsius to begin with. Anyone else have this issue? Should I replace if so do I switch to electrical?
thanks
Hello,
thanks
Maybe you engine is just that Kool!!!
Never was a fan of mechanical temp gauges...that capillary tube is difficult to route, can't be shortened to suit application, and who needs Celsius degrees? Electrical is the way to go IMHO.
Hello,
thanks
I never even heard of a mechanical temperature gauge in a car. Now I’m going to have to see what it is. 17,000 miles and 18 years on my car and never an issue with my electrical gauge.
I agree. 50 years ago there could maybe have been some truth to the idea that mechanical gauges are supposed to be more accurate. Since then I see no reason to use them.
I kind of like the mechanical because the oil pressure, oil temperature and water temperature work without electricity (all the time)
Plus there was a time when the mechanicals were full 270 degree sweep and the electricals were only only 90 degree sweep. I think that was corrected some time ago.
1 - 10 of 10 Posts
