I am trying to hook up my fuel lines and justed wanted to confirm that the bottom opening on the pump (Carter M6904) is for the fuel line from the tank and the top goes to the carb.
Murph
Thats the way they hook up on my holley.
Sorry if this is obvious, but my pump has the ports marked in and out on the underside of the pump? Maybe you didnt see it since the engine is in the chassis already....
Lukas
FFCobra Master Craftsman FFR-4618
All so using a carter fuel pump and its just the way you said, bottom from tank and top to carb.
