Need the distance between the rear body and the quick jack. Need to cut sleeves from Finish line.
Thanks Rob
Discussion Starter #3
I think your reading me wrong. Just the distance from the glass body to the quick jack. Body is on car , painted and secure.
Thanks Rob
confused...can't you just measure that w/ a measuring tape since it's all external?
Sorry Rob, I thought you were asking about the sleeves inside the trunk (which I don't use by the way). As Rich said, on the outside you can make them whatever looks good to you. I usually make them fairly short, like an inch or so, because I like to see the bumper or quick jacks kind of tight to the body.
If installing a bumper, make sure to leave enough room to get the key in and out of the trunk latch.
Norm
  • Like
Reactions: WIS89
