When installing my Mcleod Bell housing I encountered an issue with some of the mounting bolts not able to fit to the block plate. They are the top two bolts on the driver side next to the top bolt hole in the block plate. I cannot install them because they will hit the AFR heads. Has anyone encountered this....is it even an issue since these bell housing are supposed to meet many different Ford applications? Someone told me the same thing happens with the Lakewood bell housing and it will be fine without these installed. Looking for some reassurance. Thanks
