1 - 3 of 3 Posts
Here's a small tip for those just starting their build. There's several panels where you need to trace the framework onto the backside of the panels so you can mark where you need to drill. The floors and the trunk panels in particular. Here's the tip: Take the time to trace the framework before you start assembling.
I now have to mark the trunk panels and it should be pretty challenging with the rear suspension and fuel tank in there taking up all the room. :(
If you are in that position (like I was :D ) just locate the begining and end of each run, then run your marked up underoos elastic between those pionts...the top rear trunk aluminum is the worst as far as removal and replacement goes...
Thanks for the tip, Rickster. I was planning on getting my daughter to crawl under there and start marking. She used to take gymnastics so I figured she could do the contortionist thing! I'll give your idea a shot.
1 - 3 of 3 Posts
