I am planning a non-donor build and I am looking for the pedal assembly. Does it matter if I get a 87-93 or 94 to 99 with the Mark III? Also, the same question relative to the steering column. Thanks.
Non-Traditionalist (I'm not a purist, just look at
Steering column comes with the kit and if you are planning a 4.6 build you need a 96 or newer pedal box. Mike Everson is a great supplier on late model pedal box's I got an awesome one from him a couple of months ago!
Not using the 4.6. Using a 427 sideoiler FE motor. Is the steering column included in an FE Mark III? Can I use the older pedal box with an FE? Thanks again.
David O, You are correct, I guess could have worded it better. According to Larry, I don't have to worry about a steering column. It comes with the kit regardless of what motor I use?
yes on the steering column.
re: Pedal Box...if it were me, I would use the newer ones because then if you want to add the donor small hydraulic brake boost that also serves the PS, then you are all set.
Jeff,
I'm just putting parts together right now, but I went to Mike's (I live close enough to make it practicle) and looked at the two type pedel boxes. I went with the newer one because it looks stronger and costs less! One of the benifits of the MK III is having this option.
