Can I use the donor shaft (that attaches to the rag joint) and a flaming river u-joint 1709DD to tie into a FR manual rack (I'd have to go to junk yard to get shaft)? I currently have the shaft from the kit that is used for a de-powered rack but the u-joint is/ appears welded to the shaft!! Any thoughts?
What I usually do with that shaft is cut off the nasty looking rag joint and a Borgenson UV joint welded in place...makes for a tidier look.
DB I don't have the rag joint shaft but can I use it with that joint?
Limey,
i used the lower shaft from My Kit, just grind off the weld very carefully, then it taps off,
I Then used the FLA-FR1709DD From summitt racing $64.88 with my flaming river rack, looks good. if you need a pic pm me your email
jimmy O
Jim thats what I needed to know. I wasn't sure if there was splins on the end of that shaft or not! I will do that, Thanks!
