· Plodding Along
Here's my attempt to use the Breeze upper radiator shroud to make something that looks like an original AC-style radiator top mount pin. I rolled the edge of the shroud so that it could help cover the top of the radiator a bit more, then added a bent piece of scrap aluminum to look like the support arm. For the pin, I just used a piece of rigid tubing that I turned down a bit on the lathe, then cross drilled it for a brass cotter pin. I'll have everything powder coated at some point, except for the pin and the fender washer below the cotter pin - that should give just a bit of contrast.
Total cost - less than $3 bucks.
· Plodding Along
This one has been on the shelf for a while, but here's the finished product... powdercoated some of the parts black to give a better illusion of a radiator.
I used 3/16" rivets to hold the "mounting tab" to the Breeze filler panel:
