Hello,
This is my first post for my build:
FFR Mk.IV, Number 9308 Bought in March 2018, Complete kit.
Pond 482 Aluminum Block
SCAT Forged 4.250 Crank
10.7:1 Compression Forged Piston
Forged H Rods 6.700 (Chevy Spec)
Robert Pond MR Polished Heads
Blue Thunder Intake Manifold with Oil Filler & Puke Tank Holes.
TD Roller Rockers
Comp Cam Roller Cam
Comp Can Roller Lifters
Custom Racing Pushrods
MSD Ignition and Distributor (External Controller hidden behind Dash)
Holley 780cfm Vaccum Secondaries
Fuel Rail w/Mechanical Gauge
Turkey Pan
Girling OEM Reservoirs
Fluidyne Cobra OEM Radiator
OEM Coolant Pipes and expansion tank
Oil Puke Tank
Canton Oil Pan
Oil Cooler with Braided Lines & AN Fittings
OEM Style Oil Filter Adapter
Quicktime Steel Bellhousing
12" RAM GM Clutch & RAM Pressure Plate
TKO 600 5 Speed with extra low Cruise gear
Pin Drive Suspension
FIA Pin Drive 15" wheels
AVON RR Tires (295 + 265)
Old-Style (Had to for Pin Drive) IRS Suspension
Aluminium 8.8" 2.27 Diff. with Disc Brakes
Leather Seats
FFR Vintage Gauges
OEM Style Shifter
OEM Style Pedals
Herb’s Door Panels
Curtain Ferrells
Tonneau Pins
Breeze Hood and Trunk Hinges (Perfect look!)
Breeze seat mounts PLUS Adjusting rail for driver side
Trans tunnel support rods
Hidden Battery box (Over IRS)
Hydraulic Clutch Master Cylinder
Mechanical Throttle Linkage
Square LED Tail Lights with Relay Box
500Lbs Front Coils, 700lbs Rear Coils
Koni Dual Adjustable Coil-Overs
Bentley Wool Carpeting
Pictures to follow.
TD Roller Rockers
Comp Cam Roller Cam
Turkey Pan
Oil Puke Tank
Canton Oil Pan
Leather Seats
FFR Vintage Gauges
OEM Style Shifter
OEM Style Pedals
Herb’s Door Panels
Curtain Ferrells
Tonneau Pins
Pictures to follow.
