The engine turns over and fires up great. However the engine will only run for about three seconds before dieing. I have sent computer to factory twice so in theory the Vehicle anti theft, and steering wheel lock should be removed.
What else could be killing the engine?
If this is a case of the vats do I send it into FFR for third try or do hire a "local" tuner to remove it?
My donor car was a 98 corvette and I did get the starting key wiring fixed as the installation manual is incorrect.
Also note that I am bypassing the fuel pump because the grey wiring coming out of the fuse relay box for the engine does not have the voltage on it again.
Thanks for your input In advanced.
Clint
Discussion Starter · #2 ·
Fix
The solution was that factory five neglected to disable the steering wheel column lock, and because my doner car was an automatic they also forgot to disable the in park detection (RN1234)
I had to purchase HPtuner to correct the problem. Glad I got my car running just a little upset it cost me and extra $500 to do it.
