Just had computer reflashed .it starts then dies like its runing out of fuel.
If i turn key off while runing and turn back on quickly it keeps running if i keep doing that.
my bet is that your VATS isnt fully disabled. Make sure your column lock is turned off as well as that would do exactly as you describe. Then if that is not it make sure it is either fuel or spark related then go from there but i would almost guarantee it is VATS related, Check your column lock
Check your starter switch, the manual shows the fuel pump wire conected to the start terminal (wrong)and it should be on the ignitition terminal (pink and orange together)
