1 - 2 of 2 Posts
The time has come for me to part with my Factory Five Mk3. I am selling my car because my seasonal job does not allow me the time to drive it during the driving season and because of that I don’t have enough interest to finish the car. This is a very unique car, and a great opportunity to save a ton of time and money building an LS powered Cobra.
A little history on the car…This was a NON DONOR build, all new high end parts. I bought the kit from Factory Five in 2005 and had it finished the first time in 2007 with a 598ci big block Chevy and Jerico 4 spd. Because of chronic overheating and 4mpg I decided to swap in an LS crate motor and TKO600 transmission in 2010. Since then I have only put about 1500 miles on the car. I am selling the car as a roller, ready to accept your LS engine, or it can be converted to accept the engine of your choice. The odometer reads just over 3000 miles, but many of the parts including the coilovers, and fuel system which were replaced during the LS install only have about half that. I also have many brand new parts installed, including the whole front suspension, spindles, and brakes.
I have chosen to keep the engine and trans and sell the car as a roller, but you will receive all parts necessary to install and run your LS engine including custom headers, driveshaft (for TKO transmission), fuel pump/regulator, motor mounts, and TIG welded stainless radiator tubes to fit the Factory Five radiator. If you have wanted to put an LS engine in a Cobra you will not find a better or faster way get on the road. Paint aside, you could have this car on the road in a weekend of work.
In the interest of full disclosure, the car was involved in a minor collision which resulted in front end fiberglass damage in the summer of 2016. A new FFR front half body has been glassed in and fitted to the frame. The car still needs bodywork. The doors need to be fitted, hood fitted, primer/paint etc. I have ground down the mold seams and gone over the gelcoat with a block. The rear of the body needs very little work, I was just going to scuff it and paint. The car includes everything you need to be on the road except engine/trans and paint.
ASKING $20,000
Call or Text Rob at 614-561-9436
I have tons of pictures at every stage of the build.
Components included are:
FRAME:
Factory Five Mk3 frame powder coated black
ENGINE COMPARTMENT/EXHAUST
LS motor mounts welded in place
LS 4 into 4 ceramic coated headers
FFR stainless side pipes with O2 sensor bung TIG welded in
TIG welded stainless radiator tubes for LS with steam vent tube
NEW FFR radiator with 16” electric fan and aluminum shroud
FRONT SUSPENSION:
Upgraded to Mk4 front suspension
NEW upper control arms
NEW upper and lower ball joints
NEW Mk4 spindle and hub
NEW 13” 6 piston Wilwood Brakes
Koni coilovers (1500 miles)
Hurst line-lock
REAR SUSPENSION:
Winters Champ HD Quick Change rear end 10” ring gear (3.00, 3.55, 4.12 gear sets included)
Triangulated 4 link with Adjustable arms
11” 4 piston Wilwood rear brakes with new pads
Custom driveshaft to work with your LS/TKO
FUEL SYSTEM:
Fuel Safe 22 gallon fuel cell with bladder
Walbro EFI fuel pump
Aeromotive bypass regulator with gauge
Nylon braid feed and return fuel hose with AN fittings
Billet inline fuel filter
WHEELS/TIRES:
FR500 wheels (black with polished lip)
17x9 front
17/10.5 rear (2 sets, 1 set is NEW)
Goodyear Eagle F1 GSD3 255/40/17 front
Sumitomo 315/35/17 rear
Tires are ok, but not getting any younger
INTERIOR: carpet could stand to be replaced, as well as dash cover. NEW FFR dash cover goes with the car.
FFR vinyl roadster seats with adjustable track on driver side
Black leather steering wheel
Chrome roll bar (driver side)
Simpson harnesses
Autometer Ultra-Lite gauges (all electric with required sending units.)
5” 200mph speedo
5” 10k rpm tach (Resistor installed for LS tach drive)
2 1/16 short sweep electric gauges
Double-din stereo head unit with touch screen
Kicker speakers (2 front, 2 rear)
Black carpet/FFR floor mats
FFR heater
NEW Breeze vinyl door panels
Forte’s Wilwood pedal box and 3 Wilwood master cylinders
Ron Francis Wiring Harness
BODY/ATTACHING PARTS: New front half (bodywork started), original back half.
NEW hidden trunk hinges
NEW Breeze door latches
NEW FFR Mk 3 hood (I never had it installed)
NEW brushed aluminum bullet mirror
FFR hood hinge kit
NEW Finishline LeMans gas cap
NEW Finishline side louvers
FFR windshield w/ windwings and sun visors
Chrome windshield frame needs to be cleaned up
Quick Jack Bumpers
FFR Wiper Kit (not installed)
1 - 2 of 2 Posts
