Fellas-
Isn't the oil pressure sensor downstream from the oil filter on a 302? If so, and if my oil lines are plumbed backwards, wouldn't the filter bypass flap create little or no pressure on the sensor (while admittedly, there would be approximately 60 psi on the oil pump side of the restriction)? So having good pressure (40psi warm idle, 60 psi cold idle), isn't that ok?
-Chip
-Chip
