I have had with these pre-bent lines
Had a mechanic friend over to help with bleeding the brakes and to just to show off the FFR. I filled the reservoirs and we started pumping up the system. At first I had a leak at the D-block for the front brakes so we tighten it up some more, no help. Then as the fluid moved further thru the lines got a leak at the prop valve...tighten it up, no help. At that point we just kept pumping fluid thru to see what all ws going to leak. 5 friggen leaks that no mater how tight we got them they still leaked. That pretty much tells me that there is no fix-em if they leak like that. He took some of the joints apart and pointed out the not all were double flared and two of the ones that were had been flared at a slight angle and were off center. This is great I have fooled with these damn things for way too long. This was the biggest waste of time and money so far. Now I have $275.00 into these lines and I get to start all over. At this point I'm just going to cut my losses and buy some pre-flared lines and move on. Sorry just had to vent a little. This really sux!!
[ August 05, 2002, 04:01 PM: Message edited by: ORANGE CRUSH ]
