Its been too cold to work much in the garage so I'm doing stuff that can be done in my Roadster Dungeon. A little here and there its still moving forward even if its not what I want to be doing. Does this look like it will work ok?
That looks really nice. Although if those are screws, I'm guessing that getting to at least 2 of them is going to be tough with the body on.
Bruce
Discussion Starter #3
Bruce
Yes those are 10/32 stainless 100 degree countersunk going into floating avaition style nutplates. The panel is just about the same radius as the hood opening so it will be usefull.
Looks good. Another option is to make the entire panel completely removable which is what I did. I put washers as spacers on the 3/4" upper tube, and notched the panel so it slipped in between the washers. Then I used rivnuts to attach it to the inboard foot box panel. I think I have a photo or link somewhere...
http://www.ffcars.com/forums/showthread.php?t=255662
I also flipped the wiper motor around and hid it in the driver side footbox and wanted to make sure I had access to it, if I ever needed to R & R it.
Discussion Starter #5
I like your wiper flip. Slick!
I've been putting off the wipers hoping to find a non cable option.
I put an access panel in similar to that and have used it many times. You can get to the windshield bolts and clutch cable if needed. I also put an extra fuse block in there for future upgrades. Time well spent in my opinion.
